(2) Inspire 1 arms fixed for $8 total
This post was deleted for double posting and I did not post it anywhere else.
After all of the input from you guys (thank you), considering all the soldering & tiny T bits I ended up with a much more simple solution.
Flight tests to be performed soon and more details to come. Aloha
Yes you did....
So what’s this then.... >Broken arm repair Inspire 1v2
And you have posted this one in the wrong section (again).
This is Inspire 1 related so belongs in the Inspire 1 section!
Perhaps you can explain the difference in your two posts regarding your fix that use the same photographs!
Reactions: Donnie Frank
But in your original post, you said ‘more details to come’ implying you will elaborate once you have done more testing.
You even got a reply from @Dobmatt
Then you posted up a further thread on exactly the same subject using the same photographs.
You started the original post on exactly the same subject so starting another one is pointless.
This one now closed.
Bcloughpmd
