480gb cinessd shows 120gb
Anyone having this problem, I have a 480gb cine ssd that only shows 120gb.
I tried it on a Mac and a pc same result.
Any help would be appreciated.
Incorrect volume reporting is usually a sign of a bad SSD. At least one person on here is going to tell you to reformat the drive, so I'll beat them to it. I don't know how computer savvy you are but there are many options for formatting a drive. And while some might recommend formatting via the drone, it's been my experience that DJI drones don't do low-level formatting. Formatting is more a tool for troubleshooting than a fix. If the drive won't format in Windows, chances are there is an issue with the drive itself.
I don't own a RAW camera so I don't have first-hand experience with this, but I DO have a lot of experience troubleshooting and replacing SSD's. Unlike HDD's that can die slowly, SSD's tend to die instantly - one minute they work, the next they don't.
Also, if the SSD is in a housing, there's a good chance that there may be a problem with the front-end electronics. So best to isolate the SSD from any housing or front-end interfaces to check for sure.
Good luck.
Thanks,
I tried a low level sector scan, it said 111gb usable space, no bad sectors.
Same size as a 120gb unit.
Is it possible the cine ssd could be dismantled and a smaller memory unit installed inside the larger unit case?
Thanks,
It's hard to say. What does Disk Manager say? You should post a screen shot of the disk in Disk Manager: In the Run Dialog box, type "diskmgmt.msc". This will paint a clear picture of the disk's partition and file structure.
Thanks,
Off-hand, I would say "yes" with a lot of confidence. It's probably a couple screws to take the housing apart. But to be sure, you should screen capture the drive in Disk Manager to make sure that the drive hasn't been partitioned incorrectly.
New Threads
lucaskalik
