Very cool.... I'd love to see your "how to guide" if you ever have the time to put it together!
Do you feel the CF blades you're running help with that flight time? Are the motors running any hotter than stock?
very cool, make sense, will be interested to hear more about flights as you keep doing them.
best
Reactions: damoncooper
The quest for 30min continues....just picked up two of these guys to try.
MultiStar High Capacity 3S 5200mAh Multi-Rotor Lipo Pack (AR Warehouse)
Damon I am very curious if you could elaborate a little more on the set up, I am specifically interested in how using 3s batteries works, I think I figured it out that you are running them in Tandem, if so then that clears up a lot for me and I like the way that your split the weight of the two batteries, allowing the balance to equal out.
marve84
