A couple of little gimbal control issues
it seems that my Go App does exactly the same thing to the X5 whether I choose FPV or Gimbal Reset modes, Isn't FPV supposed to center the gimbal and not permit Yaw or Tilt? I can it still Tilt in FPV?
Another issue is the App gimbal control, using the screen to control where you want the camera to go. Supposedly we should be able to touch the screen and half until the blue circle appears then slide to the direction wanted, my circle never appears and the gesture is met with focus rather than gimbal movement ALWAYS. The other day after I took the craft out of storage mode and before turning it off to install the gimbal, I touched the screen and low and behold without the X5 attached the blue circle appeared and moved around as I wanted. Yes I use the scroll wheel on the left side and have the right C button set to switch between yaw and tilt, and it works fine, however there are times when I just want to do it on the screen and its of course impossible to do now.
Any ideas?
Reactions: Nicerb
tomhardyy
