- Joined
- Jan 5, 2014
- Messages
- 200
- Reaction score
- 20
- Age
- 32
- Location
- Athens, TX
- Website
- www.majorvisionmedia.com
UPDATE May 16th, 2017
Alright so after figuring out my landing gear motor is NOT broken, I've come to the conclusion the landing gear lowers past the farthest thread or section of the worm screw in the middle. It seems to get off track and only gets stuck when put into landing mode. I have had to manually unscrew it out of landing mode multiple times now and the screw it starting to get stripped.
Here's my idea: I'm going to put a small rubber spacer around the base of the worm screw so when the gear is put into the landing mode position, it cannot actually go all the way down. It will be held off by the rubber by a half a millimeter or so. I've included a photo of where I'm going to place the rubber ring. Any thoughts on this?
Original Post
Hey guys,
It looks like a servo or something went bad in my Inspire 2 today. I was on a job and it flew great all day. For the last shot of the day, we swapped batteries and took it up as usual. It flew fine and there were no abnormal warnings of any kind. When I tried to lift the landing gear manually with the remote switch, it said something like "Landing gear could not deploy. Please make sure your gimbal is safe before landing." From that moment on, no amount of resets, firmware updates, or gimbal removals has fixed it. I was running the firmware version before the most recent one. It has the numbers 2.4000 or something in it.
When I try to put it in travel mode either through the app or by pressing the power button 5 times, I can hear a tiny motor try to engage and then nothing happens.
Has anyone had an issue like this and figured out how to get it working again? DJI support was no help and couldn't tell me how to lower the landing gear manually either.
Original Post
Hey guys,
