After Firmware Update Unable to Control Gimbal X Axis
Hey all,
For the last year or so I've always had my C2 button programmed to allow my gimbal wheel to control the X-axis (left and right Pan) upon start up it controls the Y axis (Up and down), however after updating to 1.8, in the menu for changing the C2 button the only obvious option is switch gimbal mode, when I do so, and click on the C2 it basically unlocks the gimbal allowing the craft to rotate around it in a fixed position, clicking again unlocks it and causes the gimbal to follow the craft. I cannot control X-axis I've tried every setting available and nothing works.
Is there any work around for this other than downgrading? Am I missing something?
~Thanks
This should work even with never versions than 1.8. Try to delete DJI Go, reboot and then reinstall.
Chris
CandyGolds
