Welcome to InspirePilots.com
Join the leading DJI Inspire community for free!
Aircraft and RC Bricked!!!
Discussion in 'General Discussion' started by Deepak, May 15, 2016.
  1. Deepak
    Dec 30, 2015
    10
    Hi,
    I am using Inspire1 single remote. I upgraded my RC's firware by mistake via DJI GO app. Now I am unable to upgrade my AC as well as downgrade my RC.
    I have tried everything, but because my AC is not giving power to the gimbal so the gimbal stays dead even when I turn my AC on.
    Also I have tried pen drives and card readers to downgrade my RC but its not detecting the USB drives. Although it is showing the DJI GO app is connected to the RC as it is responding to few functions which are in the app.
    RC has green light which shows its connected to the AC but the small nobb which allows us to exit travel mode is also NOT working. Even in the app when I click on 'Exit Travel Mode' nothing is happening. I tried to format my SD card and USB drive multiple times but no luck.
    Please help if anyone has any clue.
    P.S. - I have been reading the forums all over the internet for more than 12 hours now, yes 12 hours. No solution at all.
  2. Ozziepauly
    Jan 2, 2014
    38
    17
    Melbourne, Australia
    Not saying this is a fix but others have used a second mobile device. Reinstall the GO APP. Once you have downgrade the RC you should be where you can upgrade the AC
  3. Deepak
    Dec 30, 2015
    10
    Yes, I used 2 android and 2 ios devices. All of them say -
    "Equipment :Inspire1
    Firmware Version:null
    Downgrade Firmware to:
    *empty space, nothing to choose*
    No available firmware to download."
    Thanks for the help though, do we have anything else to try?
  4. Tubbyengineer
    Apr 30, 2016
    54
    19
    This is going to sound silly but why isn't the AC giving power to the gimbal?
  5. Deepak
    Dec 30, 2015
    10
    That is really very weird. If the gimbal won't get the power, I don't think the downgrade of RC will help much. Thanks for reply.
  6. Bruce Bowsher
    Nov 3, 2015
    32
    Be sure to back up yur flite records before you dump out the DJI go app...
  7. Skynet1
    Apr 20, 2014
    166
    12
    #7 Skynet1, May 22, 2016
  8. Skynet1
    Apr 20, 2014
    166
    12
    It's always nice to know how you made out with the issue you were having, particularly if none of the info. provided to you had helped, and you had ultimately found a fix on your own. This is the type of info. which helps us all learn, so as to help others with the same type of concerns you had experienced.
    If you had found it necessary to send the model into DJI for further evaluation and repair, then all the best, and hopefully you will experience a short turn around time that's not all that costly to you.
    Regards,
  9. damoncooper
    Mar 20, 2014
    3,461
    1,664
    Boston, MA
    I believe you can downgrade the RC by holding down the help icon in the GO app
  10. JPA
    JPA
    Sep 30, 2015
    Is the Inspire in travel mode now?
  11. Skynet1
    Apr 20, 2014
    166
    12
    I believe Deepak may have gone Deepsix. : )
