Aircraft not update to 1.4.0.10
I update the RC to 1.3 Ok.
After I tried to update the aircraft to 1.4.0.10 several times without success.(The previous version was 1.2.1.06).
So i update the aircraft to 1.3.0.00 OK and after i tried to update aircraft again to 1.4.0.10 and not success.
I read the sd file text and show:
"The firmware on the SD card is identical to or older than the current firmware on the aircraft".
The WM610_FW_RESULT_AB.txt full is:
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2014.01.01 00:00:07 remo-con disconnect======
Packet: WM610_FW_V01.04.00.10.bin
Result: Failed.
========== 2014.01.01 00:00:05 remo-con disconnect======
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Packet: WM610_FW_V01.03.00.00.bin
Upgrading ...
Result: Success.
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
Result: Abort.
Result: Abort.
========== 2014.01.01 00:00:06 remo-con disconnect======
Result: Abort.
Help please.
Thanks.
It appears that your aircraft is already updated. Check the About section of the DJI GO app. Which firmware version is displayed there?
Reactions: Scotflieger
SheltonGre
