Check my post in this Help section. It is just below yours and refers to the latest firmware update getting stuck.
Could not open it on my iPad.
Why not try it once with no camera connected? Then if it works, attach your X4S. Hope that helps.
When you open the app click on the 3 dashes in the upper right hand corner and hold it for 5 seconds and then it will allow you to choose which firmware version you want to download. Make sure you have your remote and aircraft turned on and have the remote connected to the aircraft. I downgraded my firmware to the older version and now I can fly without all the problems of the newest version that DJI tries to force on us. I think the latest version is only good for the X7 camera and doesn’t apply to the X5s or the X4s cameras.Dears,
How are u ?? I have problem with My aircraft while updating. I didn't get any solution and the update stop in 22% for the camera and it stops
can any one help me ??
and how to downgrade the firmware
I upload the video
Are you sure that the latest firmware update is good for the x4s? I thought it was for the new x7 camera and that’s why I downgraded my firmware. Does that new firmware work for the x4s too? I’m just not sure about it and that’s why I didn’t use it. Also I heard that the new firmware gave a lot of people trouble.Don’t downgrade. Remove your camera and try it again.
Does anyone have any information about the crystal sky monitor? I can’t find anything except the user manual from DJI and it’s pretty worthless for trying to find out all the specifics of the controls.
I understand that it’s android based. What I’m talking about is the different controls and features that are specific to “it” alone!!What do you want to know ?
It’s pretty self explanatory as it’s an android based tablet with DJG and Go 4 installed.
Can I do firmware updates directly with the crystal sky or do I have to use my iPad or iPhone to download them to the remote and aircraft? If I can use the crystal sky monitor for firmware updates which cable do I use? The USB to USB or the micro USB to USB cable and connect it to the aircraft? I tried the USB to USB cable and it didn’t work. Finally I went back to my iPad and updated it that way. I just want to know if I can update straight from the crystal sky or not please. And thanks for your help. I am still learning the ropes on all this stuff.The Go apps are identical to the Android versions and have all he same features, the device specifics are things like
It also had the DJI Pilot App installed to again identical to the current release for the M200
Duel SD card slots= this is for playback from the craft and you can move image data around but you can’t record video cache directly onto them
HDMI Output = Mirror screen or have dedicated output.
USB A port for moving files around from USB memory sticks.
Bunch of screen settings like brightness and image look.
The ability to wirelessly share data from CS to another DJI Go device with Ad HOC Wi-fi.
Then you have just the usual basic Android settings, DJi use a skin over the OS so you have their custom landing page, while it will now work with some 3rd party apps it does not have the Google Play Store currently.
