Welcome to InspirePilots.com
Join the leading DJI Inspire community for free!
Anti-Collision lighting for Inspire (20 Grams)
Discussion in 'General Discussion' started by 304HighDrone, Sep 30, 2016.
  1. 304HighDrone
    Jun 14, 2016
    72
    72
    Has anyone tried this one?
    It only weighs 20g with battery. Visible up to 3 miles. Comes in either red, white and blue
    Dual Function Guardian Lights
  2. johnmont250
    Dec 30, 2014
    273
    102
    looks nice, good find, im thinking velcro'ed somewhere, but where would be the best spot?
  3. 304HighDrone
    Jun 14, 2016
    72
    72
    It must be center mass. The balance point. On top for sure. Unless you want to counter weight but that would just add more weight. It must be viewable in all directions. Velcro is what I'm going to use because it's removable. Can't wait for it to arrive.
    Nasscar][ likes this.
  4. DesertWindAero
    May 1, 2016
    158
    39
    Northern New Mexico
    But...if it's on top, can it been seen from below?
    If not, seems to me you'd need another one on the bottom.
  5. AeroMirage
    Aug 7, 2016
    803
    379
    I would think that on the bottom of the battery box would be the best. Close to the COG and far more visible.
    304HighDrone likes this.
  6. 304HighDrone
    Jun 14, 2016
    72
    72
    Underneath the battery box gives you 5 cm. The light is 4 cm. That would work and to offset the weight just move the top light down the nose some.
    #6 304HighDrone, Sep 30, 2016
  7. CvdL
    Nov 4, 2015
    13
    The Netherlands
    304HighDrone: can you share some more info on the anti collision light you are using? Thanks
  8. Nasscar][
    Apr 30, 2014
    92
    16
    304HighDrone - excellent photos, what camera are you using?
    Nas,
  9. 304HighDrone
    Jun 14, 2016
    72
    72
    My lights arrived. I ordered 3. One of each color they offered which were red, white and blue. They are much lighter than I had expected. They come with a clip attached to them. When you remove the clip it makes it less bulky and opens loop holes for Velcro to loop through almost like a belt.
    This photo shows the white light with the clip removed. The red light still has the clip attached. Note the loop holes. By flipping the battery in the opposite direction. It will change to either solid or blinking (beacon) one bird is in the air that can't be changed until it's on the ground. The manufacture gives it a 3 mile visibility rating. $19.99 each.
    I haven't attached mine to the bird yet, been super busy. I'll post when I do.
    duncanthecrow and lrh111 like this.
  10. William Gaddy
    Aug 21, 2016
    366
    151
    Hey folks -- I posted a youtube video of my visual notes for both these and the lumecubes (and in combination):
    Hope you all find this helpful.
  11. FlyingPhotosKR
    Jun 8, 2016
    28
    5
    Be very careful about anything on top of an Inspire1 because your satellite receiver is on top and if you pick it up to carry it when it is on (but not blades turning LOL) it loses satellite reception as your hand grabs it on top.
  12. William Gaddy
    Aug 21, 2016
    366
    151
    No GPS signals were harmed in the making of my video above -- all 4 lights mounted on the main arms, out of the way of the retracting landing gear bars. But a good point -- I've mounted small cameras on top, but only when I was prepared to fly P-ATTI exclusively...
  13. NRR
    NRR
    May 6, 2016
    25
    How can I find the link to this youtube post?
  14. NRR
    NRR
    May 6, 2016
    25
    Disregard... The video just populated in the post.
  15. IrishSights
    Jan 14, 2014
    2,042
    499
    Bangor, Northern Ireland, UK
    At 20g it doesn't matter where you put it. To light for any practical effect on balance point/CoG. The Inspire will fly as if it wasn't there. Try carrying a Sony A6000 at 600g+! (Even at that it flys great, just shorter flight times)
    PFAW Holder
    BNUC-S Qualified
  16. BobbyPhillips
    Oct 2, 2016
    8
    Can you provide a source for the mounts used on the Lume Cubes please ?
  17. William Gaddy
    Aug 21, 2016
    366
    151
    Hi Bobby: The mounts are actually sold by LumeCube themselves: Lighting Kit for DJI Inspire Drone
    The mounts are pretty cool because they can not only be used with LumeCubes, but other attachments with a 1/4" - 20 pitch tap.
    Cheers
  18. BobbyPhillips
    Oct 2, 2016
    8
    Thanks William for the quick response and info.
  19. go fast
    Jul 16, 2015
    277
    122
    Miami Fl.
  20. BobbyPhillips
    Oct 2, 2016
    8
    That's certainly bright enough ! Which light and mount are you using there?
