Any Carbon Fibre 1345T Props?
I've been looking for a new set of CF 1345T props for my I1 v2 but there seem to be none out there?! There are plenty CF 1345S but not sure why they dont make CF 1345T, unless I've been searching a wrong code...Anyone has any idea? Please help.
Reactions: Stretch1100
The t-motor 14x4.8 props are not quick release. They have two 3mm holes spaced 12mm apart, with a center hole 5mm. The inspire 1 motors have 3mm holes spaced 13mm apart, so you will need adaptors to make them work. These props are of very high quality which is why they are so expensive. To be able to use them on your inspire 1 you need to get the adaptors, which are very expensive too. I use these same props on my I1, and have now for almost the last 2 years.
No, this is not carbon fibre.
If you are looking for the same QR mech then I doubt you will find it.
The other option for you is to get some screw on plates that you can then fix some CF props to :)
You just have to make sure you get the right ones. Search the forum there are people on here who are using CF props although they are most likely using 1448's ;)
Reactions: Toan Doan
marbeyacharm
