Welcome to InspirePilots.com
Join the leading DJI Inspire community for free!
At what altitude will landing gear lower?
Discussion in 'Inspire 1 Discussion' started by CCDD, Jun 13, 2016.
  1. CCDD
    Apr 20, 2016
    124
    33
    US
    Is there a "safety" in which the Inspire will stop before touching down should the landing gear not be lowered? Although I have it set to both auto raise and lower, I often activate the lowering of the gear rather than having it operate automatically.
  2. unyks
    Jan 28, 2016
    354
    178
    The is no safety, if the bird goes down it will use the camera as the landing gear.. ;-)
  3. CCDD
    Apr 20, 2016
    124
    33
    US
    So when should the gear lower? I often bring it down manually(gear) when about 15ft or so from landing.
  4. unyks
    Jan 28, 2016
    354
    178
    I always do it manually because I switched this feature off. On emergency situations (RTH) the landing gear will go down automatically
    Chris
    Scotflieger likes this.
  5. The Editor
    The Editor Moderator
    Staff Member
    Aug 7, 2013
    8,079
    4,540
    No Idea - never used it, never will.
  6. Scotflieger
    Mar 29, 2015
    1,254
    586
    Buckie, Scotland, UK
    The auto landing gear will only activate when you reach 0.8m (2ft). However, as pointed out above the aircraft will not pause while it lowers so if you have any negative vertical speed you WILL hit the ground without the gear down. Don't trust it. The Adaptive Landing Gear option is only useful for raising the gear after initial takeoff.
    I generally lower manually at about 10-15m before I do my reversing into the landing pad (ie. aircraft facing away so I don't put in the wrong stick inputs).
  7. CCDD
    Apr 20, 2016
    124
    33
    US
    Very helpful Scot, thanks!!!
  8. David Herman
    Mar 13, 2016
    23
    6
    Also it seems fussy about the terrain the sensors read to detect landing so I now manual up and down, stay in control.
  9. The Editor
    Staff Member
    Aug 7, 2013
    8,079
    4,540
    Just out of curiosity.......(I've never really seen a decent answer/argument for)........
    Why would anybody want to use self lowering landing gear.
    "In case I forget" doesn't count. :p
    Actually, why would anybody need to use auto take off for that matter but that's a different discussion.
    B Dog likes this.
  10. huppe
    Jan 11, 2015
    953
    348
    Yes I think it's a useless feature too.Never use it and also it looks nice when you do it by yourself.
    But you gear will lower at about 3 ft
  11. MacDyver
    Nov 29, 2015
    297
    110
    South Florida
    To impress folks who know less about quads than me?
    The Editor likes this.
  12. Dave Armbrust
    May 27, 2016
    231
    103
    Thats easy. Because it is cool to watch it transform all on it's own. It almost as it it is alive!
  13. dopeytree
    Oct 8, 2015
    103
    22
    Somerset, UK
    Just for infos it still auto transforms if you use the CSC command. This way the motors start up on low power on the ground so you can check them then when you've happy you can go chucks away and open the throttle. Much cooler than hitting an ipad button ;)
  14. Flying Monkey
    Oct 14, 2015
    29
    8
    If you have if you have not disabled it the landing gear will automatically deploy and retract at approximately 4 feet. I personally have my automatic landing gear operation shut off. Just remember if you shut it off to remember that you did. The reason that I shut mine off is that some of the pics that I take start at about 1 foot as I Buzz down down the street with my camera pointed up making whatever or I am shooting look large and tall. It is a perspective shot.
