Balancing (3D Printed) 'kit' Question
Every lens filter combination is different. I just use a Velcro stick on dot on the back of the camera body for an added counterweight, or use a filter on the front if needed. Just tilt it around and see if it rests in the same spot without swinging to somewhere else while turned off. Not that big a deal really.
Mostly, I use a Lee 10cc green color correction filter (Cut and mounted in an old 46mm filter holder, or the gel alone placed behind a ND filter.) with my lenses to correct the awful magenta cast of my X5S camera since DJI does not allow a tint adjustment while using manual white balance in GO 4 and balance accordingly.
Thanks Casey, I understand about the CC filter. My son prints 3D and i found files for weight holders back and side for x5. My question are the x5 and x5s same shape profile and clearance? John
CandyGolds
