Balancing Props on V2
Thanks, I ordered that one but it comes with a small circular end that doesn't match the larger rectangular slot on the props.
That rod is designed to balance the props ON the hubs. Just did mine and two sets were extremely out of balance. It works beautifully.
So you take the hubs off the Inspire?
Yes. Assemble the lock / hub / prop and then balance as a one piece unit. This way you are balancing all parts that rotate on the motor. I even marked which props go with each hub assembly so that I always use the same set that were balanced together initially.
SampleOklahoma
