Battery error - got me scared
What might be happening here?
Any ideas? Where can i see more log data?
Cells are all in nice balance but temp is a bit on the high end. You should be able to see the battery log further down in the battery settings menu (can't recall if it's under Advanced Settings there on the bottom or not).
That could be an issue with the small pins that connect the battery to the AC. That is a (I believe) a serial connection for the battery to 'talk' to the AC. Sometimes those pins don't make good contact with the battery. If that IS the problem, you can clean those contacts by using a pencil eraser
Didn't want to start a new thread so I will add to this, as long as the OP doesn't mind...
I started noticing that during initial start on 2 out of 3 of my batteries as the Inspire 1 gets connected to the controller where the top left read "Ready To Go (GPS)" it will go through the cycle and say "Battery Error" then continue through the setup. I haven't had any flight issues, every time I've noticed this I have checked the battery section and saw no issues... I use the DJI 4 Battery Charging Hub - any suggestions?
I have seen this also
Reactions: LevitatedMedia
palakkhanna1
