Case for FPVLR inspire radio...
My fpvlr advance are otw from tony.. now i am looking for case that can fit my radio .. any idea ? :)
I suspect you will have to go with a Pelican case with the "pick'n'pluck" foam and make custom cavities for the radios.
Not sure if you guys have found a case yet but I got the perfect one I will try to send you the link KUDUCASE awesome on Amazon $64.71 it is a tight fit but works well you will not find a higher grade/quality case out there
Hi,guys,i just got fpvlr kit with boosters and fitted to stock case,just very small amount of foam need to cut,here is pictures how it's looks like
Look good to me... i going to try ite when i back home... does it hit the inspire landing gear or cover? And do you cut the battery place as well ?
Hi fei8820,it touching arm and frame,but you can place something like soft foam or rubber.But i'm not worying about it
Tony has made a new mount which will render that case unusable I believe. :(
MoraPartee
