Do you have a good example of a commercial product that is available?A 1000 watt pure sine wave or modified sine wave inverter connected directly to the battery with the proper sized cables would work well for two I2 Inspire chargers.
I do not have the spec sheet in front of me - would this run two separate chargers at a time safely. I bought two chargers so I can charge 4 TB50 batteries at a time. I am going to do some flying and filming in remote places in the desert and I am willing to run my truck to charge them but I wanted to cut down the run time to about 1.5 hours for my 4 sets of batteries.I have the 2000 watt big brother to the one I am linking and will probably buy the 1000. I will probably set it up with an aux battery in the bed of my truck so I wouldn't have to worry about the truck main battery running down. Amazon.com: Xantrex 806-1210 PROwatt 1000 SW Inverter: Xantrex: Cell Phones & Accessories
Why would you buy a 1000-1200 watt inverter to charge your batteries when the DJI power supply is only capable of 130-180 watts? (Spec is: Output A, 130 watts, Output B, 180 watts).
I've had problems using anything less than a 700W inverter.
Works fine for me charging using the i2 charger. If I plug in a phantom charger then it doesn't have enough power to charge both.I've had problems using anything less than a 700W inverter.
Schumacher 700W inverter. The DJI charging unit kills the inverter every time I plug it in. I even tried a 1000w inverter, the same result. But, that is via a 12v charging outletWorks fine for me charging using the i2 charger. If I plug in a phantom charger then it doesn't have enough power to charge both.
What are you using!
Using the outlet in my car with what I posted and no issuesSchumacher 700W inverter. The DJI charging unit kills the inverter every time I plug it in. I even tried a 1000w inverter, the same result. But, that is via a 12v charging outlet
So how much D.C. Current is used by a 1000 watt inverter while charging main batteries? I see a separate battery pictured, trying to determine how long you could use an inverter on the vehicle battery before it goes dead..
