Cinelight and Premiere frame rate issues
I've been using Cinelight with Premiere using the Lumetri functions to adjust the raw video. There's one bug that I am finding. All my footage that I shoot has been shot in 3840X2160 30 frames. At least it say 30 in the go app. When I bring it into Cinelight it says it was shot in 29.97 which is fine. However when I export the footage out as DNG for compatible with Premiere it exports into Premiere as 24 frames a second. I attached 2 pictures showing the issue. One is Premiere showing its in 24 frames and the 2nd one is of cinelight showing its in 29.97 frames.
I've tried all 3 different versions of cinelight including the latest 9.26, 9.17 and 9.18
Fixed in the latest available X5R firmware. In the meantime you can adjust existing footage manually after importing into Premiere
I've been meaning to do some tests , but maybe someone has already....
So in the Go app (latest as of June 16, 2016) the 4k options are 24 and 30 fps.
Are they really 24 and 30? Or are they 23.97 and 29.97?
Frem1962
