Control X5 focus using C1 button - also tilts camera.....
As title says, I can hold down C1 and using the wheel adjust the focus, but it also tilts the gimbal.... any solution to this?
I didn't know that feature was there, thanks for the info. I just check mine and as long as I have the C1 depressed all it does is focus. When I release C1 pitch and yaw function normally.
Reaaign them to what?
Anything you want - they just need to be changed to another setting if they are giving problems like the OP.
Then when you reasign them back they should work as expected.
Sometimes they lose their marbles! (setting)
Reactions: SanCap
GroverBaez
