M600 Controller Differences?
For anyone to answer this question, they're going to have to own a Pro and non-Pro version of the M600. I doubt anyone does. You can go to the DJI website, which will give you the spec. for both birds and both controllers.
You don't have to own both, you just have to know what the differences are.... go to DJI' website and you will find that the controller part number is same for the Matrice 600 pro as the Matrice 600...they both use same base fc, and the M600 can be upgraded to the Pro.
Reactions: Donnie Frank
The controllers are the same, The pro is just a upgrade to the fc and will not affect your controller.
Its also the same controller that might be sold or advertised as a Lightbridge 2 controller (or ground station). LB2 was integrated into the M600 and M600 Pro and also sold as a stand alone transmission system with an air module and the remote controller that could be used on any custom built aircraft. It played very nicely with their A3 controller - which is the FC in both versions of the M600.
alexzazz
