- Joined
- Dec 5, 2015
- Messages
- 41
- Reaction score
- 4
- Age
- 53
Is it possible to move the camera without a 2nd controller? I remember someone was tilting and panning the tablet and the camera was doing the same.
thanks gruv, where can you adjust that sensibility?Yeah I'd crank down the sensitivity on that as well before you try it, i find it is difficult to get slow movements (that is on the X5 though so the X3 is probably easier). As a note: the gimbal must be in free mode for you to do the finger drag, cannot be in follow or FPV.
Same with the X3 - you can assign a C1 or C2 to switch between pan and tilt.I'm not 100% sure if this applies to the Inspire 1 with X3 but I know on the Inspire Pro with X5 you can use C1 to switch the function of the wheel (on the top left of your pilots controller) between panning and tilting. If you want to both pan and tilt at the same time, your best bet is to tilt using the wheel and pan by yaw'ing the inspire in follow mode.
Ah yes, forgot about good old C2! Thanks for the clarification.Same with the X3 - you can assign a C1 or C2 to switch between pan and tilt.
