DJI Battery Charging Hub
Cape Town, South Africa
www.nickmuzik.com
I see there are plenty of threads regarding the SmartPower Charger, but none on the DJI charging Hub. The DJI one is much cheaper, has anyone got anything to say about it, good or bad? I'm thinking of getting one ......
I should mention that I do not own a SmartCharger, and I'm personally reluctant to use non-OEM (original equipment manufacturer) equipment. If DJI made it (or warranted their batteries and remotes are charged correctly by it), then I'd consider it fairly seriously. I'll probably end up with multiple DJI chargers.
mTp
Reactions: sirnikolas
mTp
Enjoy the mess of cords.
Hello, I have one question:
When I use the HUB to charge the TB Batterys and after finish I would not push it off.
What can happend, when the Battery stays one or two month at the hub?
Would the hub notice, that the battery lose power and load again the Battery?
I ask, why I often read that unused Batterys often brick and lost all power.
Regards from germany..
Bernd
emmaava607
