DJI GO 4 Crashed/Auto Closed
Jakarta
www.yulianusladung.com
Just recently upgraded my DJI GO 4. And somehow it crashed while I am using it. I am runing on iPhone 7+ (iOS 11.1). Anyone have the same problem and have the solution for it?
Confused. You say you are running iOS 11.1 (Is it 11.1.1 or 11.1.2 as mine has 11.1.2) and you show the update photo to 11.2.
Are you asking if 11.2 fixes the crash on your 11.1 (whichever one 11.1.1 or 11.1.2)? I'm running 11.1.2 and hasn't crashed yet on iPad Air 2 with GO 4.1.18.
Always make sure that GO is the only running application ! and turn off WiFi. If you use such as Litchi always ensure you kill the application before opening Go and the same in reverse. Its simple double click the home button and swipe to remove the application.
The GO application is designed to be the "sole' running application and has some strange issues when other apps are running. Obviously DJI cant fix these as they will never have a mix of applications running on their development tools.
So do exactly the same....
fairyfarmshempgummies
