DJI Go iOS App v2.4.3 released... has issue (workaround found)
Central IL - USA
Late yesterday.. the new version hit the App store...
I mindlessly updated this AM... went to try to fly a while ago...
It seems to not work... :rolleyes:
Crashes out when you go to connect to camera... :mad:
I found several other posts around where others are having same issue with 2.4.3...
Suggest you DO NOT upgrade... till this is sorted out... ;)
DJI GO on the App Store
Bird flew fine before on App 2.4.2 on a iPad Air 2...
I have FPV Camera App also... it connects fine still... as does FPV Mission Planner
Flew with that a couple of flights today with no serious issues... (2.0 beta) o_O
On Edit... see below for a workaround...
In short... have to delete and reload new version to get it to work... :rolleyes:
Suggest you DO not upgrade till this is sorted out... ;)
What iOS version are you running.
What Apple platform?
Same here, fixed it by backing up flights, delete the app, and then re-installed.. Seems to work on the bench, but I have not done a test flight. ios9.2/Ipad air2
Reactions: John Alan
About to be dark here... :eek:
But a 5 minute test hop was uneventful... :cool:
Thread title changed...
First posting... I added edit to explain situation...
Still bench testing to confirm full function...
Reactions: Highrpm955
Installed the update - on my iPhone 5 s I had to uninstall and then do a fresh install. On my iPad Air 2 I just updated and all works well.
fairyfarmshempgummies
