DJI Inspire 1 IMU Broken?
Hello,
Got a Inspire 1. The IMU status shows normal, but when I go to the advance menu there is no values showing up on the IMU, when I hit check/calibrate IMU nothing is happening. I took out the flight controller and swapped in a known working one onto this issue drone and everything is working fine. I'm guessing this means the IMU part of the flight controller is toast? I took the flight controller apart and visually it looks fine, ribbon cable is good, I think the flight controller part is fine but not the little IMU... I cant get at the IMU cause its sealed really good... Any thoughts? On a side note I didn't expect to find a micro sd card inside the flight controller circuit board, this must be where the flight data gets logged too...
GarfieldBu
