DJI Inspire 1 Single Units In Stock - Same Day Shipping
Jacksonville, FL
www.builtdrones.com
http://www.uav-outlet.com/products/...ote-quadcopter-with-integrated-4k-camera.html
A COMPLETE READY-TO-FLY SYSTEM
Everything you need is included and ready to go offering you a complete aerial film making tool in a box. Just add a mobile device or screen for live HD view.
ADVANCED, READY-TO-FLY DESIGN
Imagine holding the future in your hands. Designed to be powerful while lightweight, flexible while providing the stability you need, the Inspire 1 is DJI’s most advanced complete package. All of the latest aerial technology is packed into one simple, ready-to-fly system, putting you in the sky within minutes.
TRANSFORMING DESIGN
Strong carbon fiber arms lift out of sight, transforming the way you shoot. Get a full, unrestricted 360° view of the world below and create images like never before.
4K CAMERA
Shoot up to 4K video and capture 12 megapixel photos with the Inspire 1 camera. The lens consists of 9 elements in 9 groups including an aspherical element producing extreme clarity, while Adobe DNG RAW support gives you the power to make every shot a masterpiece. Everything is better in 4K.
MODULAR, UPGRADEABLE SYSTEM
Inspire 1’s gimbal and camera system can be removed from the aircraft for safe transport and future upgrades.
LIVE HD VIEW
A real-time feed from your Inspire 1’s camera is displayed in 720p HD on your mobile device giving you a perfect view of what the camera sees to frame your shots.
This is made possible by an all new and improved version of DJI's Lightbridge technology which can transmit video from up to 2km away.
CREATE TOGETHER
For an even greater level of precision, use a second remote controller and fly with a friend. With two operators controlling the same Inspire 1, one person pilots the flight path while the other aims the gimbal and camera.
Each user can have their own screen to see exactly what is being shot in real-time. By working in tandem, you’re capturing shots that are more complex and artistic than ever before.
FLY INDOORS AND WITHOUT GPS USING VISION POSITIONING SYSTEM
Indoor flight has always been a true test of skill for all levels of pilots. DJI’s new Optical Flow technology uses a specially designed camera as well as sonic waves to bring simplicity to flying indoors. This technology allows the Inspire to hold its position, stop when the controls are released, and respond to your commands even when GPS is unavailable.
INTELLIGENT POWER MANAGEMENT SYSTEM
A fully integrated intelligent battery powers your Inspire 1 and virtually manages itself.
When in flight, your remaining battery power is shown live, letting you know how long you can continue to fly. Advanced algorithms calculate the distance of your aircraft and estimated time to return home, letting you know when it’s time to fly back.
The battery tracks the voltage of each cell, the total lifetime charges and discharges, and the overall health and battery status. All this helps you keep your Inspire 1 in the air and flying for years to come.
DEDICATED CONTROLS
Take absolute control of your Inspire 1 with DJI’s most sophisticated remote controller to date. Featuring dedicated buttons for photo and video capture, a gimbal control dial, an integrated rechargeable battery and more, it’s easy and intuitive to fly. The controller has an HDMI and USB port allowing you to connect mobile devices or compatible screens.
OPTIONAL DUAL-OPERATOR CONTROL
Fly with a friend and share your vision. Achieve shots that never would have been possible alone by using two remote controllers. One person flies, while the other controls the camera.
EASY, SAFE FLIGHT
Even if you’ve never flown before, taking off and landing your Inspire 1 is easy and safe. It takes just one tap to make your Inspire 1 takeoff and transform, ready to start filming. Then tap again to have it transform into landing mode and land.
When GPS is available, the Home Point (the location you are standing) automatically refreshes, so your Inspire 1 always knows where you are even if you move around. When you tell it to come back, or in case of an emergency, it knows exactly where to go and land safely.
FULL-FEATURED APP
Take complete control of your camera and flight system with a comprehensive mobile app. Everything from manual camera controls to flight telemetry and even auto takeoff and landing are just a tap away, with more functions and updates coming soon.
  • Aircraft
  • ModelT600
  • Weight (Battery Included)2935g
  • Hovering Accuracy (GPS Mode)Vertical: 0.5m, Horizontal: 2.5m
  • Max Angular VelocityPitch: 300°/s, Yaw: 150°/s
  • Max Tilt Angle35°
  • Max Ascent Speed5m/s
  • Max Descent Speed4m/s
  • Max Speed22m/s (ATTI mode, no wind)
  • Gimbal
  • ModelZENMUSE X3
  • Output Power (With Camera)Static: 9W, In Motion: 11W
  • Operating CurrentStation: 750mA, Motion: 900mA
  • Angular Vibration Range±0.03°
  • MountingDetachable
  • Controllable RangePitch: -90° to +30°, Pan: ±320°
  • Mechanical RangePitch: -125° to +45°, Pan: ±330°
  • Max Controllable SpeedPitch: 120°/s, Pan: 180°/s
  • Camera
  • NameX3
  • ModelFC350
  • Resolution12.0MP
  • FOV (Field Of View)94°
  • CMOSSony EXMOR 1/2.3”
  • Lensf/2.8 (20mm equivalent), 9 Elements in 9 groups, Aspherical lens element, Anti-distortion filter, UV filter
  • Still Photography ModesSingle shoot, Burst shooting (BURST: 3/5/7 frames,AEB: 3 or 5 bracketed frames at 0.7EV Bias), Time lapse
  • HD Video Recording ModesUHD (4K):4096x2160p24/25,3840x2160p24/25/30, FHD:1920x1080p24/25/30/48/50/60, HD: 1280x720p24/25/30/48/50/60
  • Max Bitrate Of Video Storage60Mbps
  • Supported File FormatsFAT32/exFAT, Photo: JPEG,DNG, Video: MP4/MOV (MPEG-4 AVC/H.264)
  • Supported SD Card TypesSD/SDHC/SDXC Micro SD, Max capacity: 64GB. Speed: Class 10 or higher
  • Operating Temperature Range0°C to 40°C
  • Remote Controller
  • NameC1
  • Operating Frequency922.7MHz~927.7MHz (Japan Only), 5.728GHz~5.850 GHz, 2.400GHz~2.483GHz
  • Transmitting Distance (Outdoor And Unobstructed)2km
  • EIRP10dBm@900m,[email protected][email protected]
  • Video Output PortUSB, HDMI
  • Power SupplyBuilt-in battery
  • ChargingDJI charger
  • Dual User CapabilityHost-and-Slave connection
  • Mobile Device HolderTablet or Phone
  • Output Power9W
  • Operating Temperature Range-20 to 40°C
  • Storage Temperature RangeLess than 3 months -20 to 45°C, More than 3 months 25°C±3°C
  • Charging Temperature Range0-40°C
  • Battery6000mAh LiPo 2S
    • Battery (Standard)
    • NameIntelligent Flight Battery
    • ModelTB47
    • Capacity4500mAh
    • Voltage22.2V
    • Battery TypeLiPo 6S High voltage battery
    • Energy99.9Wh
    • Net Weight570g
    • Max Charging Power180W
    • Battery (Optional)
    • ModelTB48
    • Capacity5700mAh
    • Voltage22.8V
    • Energy129.96Wh
    • Net Weight670g
    • Vision Positioning
    • Velocity RangeBelow 8m/s (2m above ground)
    • Altitude Range5cm-500cm
    • Operating EnvironmentBrightly lit (lux >15) patterned surfaces
    • Operating Range0-250cm
    • Charger
    • ModelA14-100P1A
    • Voltage26.3V
    • Rated Power100W
    Included in the Package
    • Aircraft(x1)
    • C1 Remote Controller(x1)
    • Mobile Device Holder(x1)
    • ZENMUSE X3 Gimbal and Camera(x1)
    • ND Filter(x1)
    • Propeller Pair(x4)
    • TB47 intelligent battery(x1)
    • Charging cable for Remote Controller(x1)
    • Intelligent Battery Charger(x1)
    Other Options Available from DJI
    • TB48 intelligent battery
osttopstconverter
