DJI INSPIRE 1 V2 PRO BLACK EDITION
LSP
DJI INSPIRE 1 V2 PRO BLACK EDITION with custom case and a load of other bits! - £3000
This is a great piece of equipment that has been used and maintained as per the manufacturers recommendations. The batteries have always been stored as recommended by DJI. Only selling as upgrading to the Inspire 2 for work. Attach any device (ipad, iphone etc) and this unit is ready to go!
Included in the sale:
INSPIRE 1 V2 PRO BLACK EDITION (Total flight time: 7hr29min)
X5 Camera with DJI 15mm lens
Olympus Zuiko 14-42mm lens
MR Accessories Inspire case - custom designed case specifically for securely housing this aircraft without needing to raise the landing gear
1 x Lexar 633x 16gb micro SD with card reader
1 x Black TB47 4800mAh (came with aircraft - 14 charges)
5 x White TB48 5700mAh (various levels of usage from 29 to 47 charges) there are some small marks on the battery casings from usage
1 x Black Controller (set as Master) with blue protective cover (removable)
1 x Silver Controller (set as Slave) with red protective cover (removable)
1 x 180w (fast) charger
1 x 100w charger
4 x used props, 4 x new props
2 packs (4 pcs total) new unopened 1345T Quick release prop kits replacement Part No.70
1 x WT 150w max Power inverter for in car charging between locations
Various spare grommets, lanyard, tightening tool and cables to fit Apple and Android devices
1 x X5 Osmo adaptor - grab an osmo handle off ebay and you can use the X5 camera as an excellent handheld gimbal
Value of all this is...plenty! So grab a bargain.
Items listed elsewhere so sale may end early.
UK SALE ONLY.
Collection from Chilterns preferred but otherwise the whole case will be shipped with insurance.
jammartin
