DJI Inspire buying an inverter or a portable generator
Hey everyone, I just got my smart power charger for my Inspire 1. I'm contemplating on buying either an inverter for my truck or a portable generator to charge my batteries out in the field. I was told I would need a pure sine wave inverter. Need as much input as I can get on this, not too familiar with either a inverter or a generator.
I would like to use either or to charge 6 batteries, 4 with a smart power charge, and the other two with two regular chargers. Now, for the two portable chargers im looking at the
http://www.amazon.com/Earthquake-11613-Generator-Discontinued-Manufacturer/dp/B00FL89I2W
and the
http://www.amazon.com/Hyundai-HY2000si-2200-Watt-Portable-Generator/dp/B004919NEK
___
ALL input is appreciated, what are you guys using? Thanks
and the
___
Hey RedHawk..
welcome to inspirepilots.com. ..
inverters are good if you don't mind leaving your vehicle running on scene. ..must run motor to maintain the vehicles battery ..
I use a 400 watt inverter that plugs into the cig lighter that easily charges two batteries at a time..it was 80.00 usd..
the hyundia looks good and would probably run at half load with six batteries charging. .
I'm not sure how many hours you spend working ,but you might want to weigh the cost of a generator vrs. the cost of a couple more batteries. .
Reactions: RedHawkUAV
I used to use an inverter that was connected to a deep cycle battery that was connected to an isolator. It was great for all of the lipos that I ran with other RC stuff. Never had to worry about draining the battery or leaving the car running. Not sure if I would trust that setup for a smartpowercharger setup though. Stay with the Hyundai generator. It's probably quieter and has cleaner power.
cruzamikayla
