Do i need to calibrated compass ... for a new locations that 100 kilometer away ?
I going to having some aerial photo tomorow.. will travel around 100km from the place i used to fly... do i need to recalibrates the compass ? I will going to a place like very big ferrealloy factory... to have some shot...
Please advice...
thanks
Please advice...
thanks
Personally, I would not. I regularly travel over 250 miles to a location and never recalibrate anything - it is not necessary.
However, ALWAYS check your mod values before EVERY flight (even swapping batteries).
If they are not right do not take off.
Good tip - I have checked the manuals and cannot find any reference to what sort of range the mod values should be. Can you shed any light?
Thanks i just finish my mission today it was very windy.. i take off more than 300meter for clear shot... around 1.5km everything went perfectly. Now i would like upgrade range extender... at the future is not about long distant i get.. but to make sure i have 100% in control of my video n the aircraft...
So, If I understand you, Would I be correct in doing a compass calibration and noting the values when completed and then use those values as a guide for checking them on later flights.
Or is there a bet way of getting the correct mod values for my part of the world (UK)
Very interesting wrt Compass mod values. I was under impression 1400-1600 was the acceptable parameters no matter location.
Do the parameters vary dependent on where you are on the planet a bit like magnetic variation when turning a grid compass bearing into a magnetic one? It would make sense if it did-but I have only seen the 1400-1600 guideline given.
Can anyone elaborate? Do we need to compile a sticky with acceptable mod values for specific locations worldwide?
Thoughts-as the cat is thrown amongst the pigeons!!
emmaava607
