Drone Deploy distance lines
Is there any easy way to draw grid lines on a drone deploy map other than trying to manually do each one? Is there any app out there that I could take the drone deploy map and upload it and have it draw them for me?
I mapped a piece of land but I need 4x10 grid lines drawn over the land.
My experience with Drone Deploy is limited but here's what I've figured out so far. Drone Deploy will determine the grid lines when you create the boundaries of your scan/search area. The higher the altitude, the less grid lines it will use. The lower the altitude, the more grid lines. Also, the more overlap you use, the closer the grid lines.
Drone Deploy will allow you to plan your flight either on their website (and sync it with your tablet) or you can do it directly on your tablet using the Drone Deploy app. HTH
EarthmovingAdelaide
