I bought it and installed it myself. The sleek integration into the nose cone was one selling point for me, although it's just 3D printed parts. Not the same material as the stock body. Also the fact that it utilizes the existing power system is key. I didn't want to worry about buying/flying extra LiPo's just for the FPV system. The entire wiring harness is custom made and sized to plug n play with the components in the kit (soldering still required to the PDB and GPS puck). The transmitter has a custom made case that secures it to the 4 screws on the tail of the bird (replaces the nameplate). And it's the only vendor I could find to offer an Inspire OSD that taps into the bird's GPS data. For me, it matches the workflow of my 1300mm octo, so it's worth the investment. And it still fits into the factory foam footprint for cases.
Downsides are:
-can't tilt the camera
-doesn't display altitude, pitch/roll, or vertical speed
If you already have a receiver/monitor solution for 5.8ghz, I could see how the full kit would be a waste. I needed the Black Pearl diversity receiver monitor since my big bird uses 1.2ghz
All in all, I'm thrilled with it!
