Dual Controller doesn't have tilt control
The ATL
Hello All -
It's been a minute since I've flown and it seems that the second remote when in slave mode doesn't allow for up/down/tilting no matter where it's mapped. In single flyer mode the camera tilts fine.
I've refreshed I2 w/ latest software x twice. Deleted and re-installed Dji go4 on both ipad/mini ipad.
How is there a way to update the 2nd controller? I'm thinking there's some incompatibility to not let it tilt. Any advice is appreciated! Thanks!
Hello All -
Try reversing the roles of the controllers to make sure this isn't a hardware issue with the joystick.
Hello All -
Were you able to remedy this? I have a similar situation. Main control is Cendence w/ Crystal Sky. Always works. Slave is original, previously unused Inspire 2 controller, with iPad. I get a valid connection between the master/slave, and can see changes made between them (I mean if I change settings on either, it reflects on the other one). I can even hand gimbal control back and forth seamlessly. Also, when I take control with the Cendence/master, I *do* have gimbal control. But...no matter what I try, I cannot control the camera with the original Inspire 2 remote (slave).
The slave remote has been on a shelf for a while, so I’m sure it’s FW is old. However, I received no prompts to update when launching the app (which I found odd). Besides that, it seems that if there was a FW compatibility issue, then certainly *everything* else on the slave/app wouldnt have worked?
SpiderJackett
