Dual mode camera, camera moves on yaw.
We have a dual system up and running well on the inspire but have noticed that when the pilot yaws, it also moves the camera about 10 degrees which of course interferes with the camera ops movements.
Is there any way to disable this in dual mode. I understand the functionality of this with a single user to smooth out turns on video but not required for 2 man set up and is spoiling otherwise perfect takes.
Have you changed your FPV mode? The paper airplane icon on the left side will change the setting so that the cam stays level with the craft or level with the horizon.
Hi. Yes it's set to stay level with the horizon. That's not the issue. The issue is in dual mode the camera op surely should have TOTAL control of the camera but when the pilot yaws left or right the camera also does slightly to smooth out jerky footage. This needs to be disabled but can't see that it's currently possible.
ConnorStewart
