Extension For 11" iPad Pro 2018
Can anyone recommend me an extension that I can use for the i2 controller? I purchased the Polar Pro a while back but it just doesn't hold it securely.
If I understand your setup correctly, have you considered a tray? . . . such as the Secraft with an extendible mount? Here it is with a Cendence and a 12.9" iPad. I used it originally with a standard Inspire 2 controller as well. The Cendence fits with a small adaptor kit that just has 3 or 4 parts. It definitely holds the iPad securely. I even leave the leatherette cover on it, just folded back. The tray with back/shoulder strap also helps holding the weight of both units. I hope this helps, AerialPerceptions!
Reactions: Donnie Frank
Does the controller still fit in the case? Or do you have to remove the outer skeleton?
This is why I love this place! Exactly what I was looking for! Thank you so much.
Reactions: Jetcar
Hi Donnie Frank. I doubt it will fit in the original case. I use an Ape Video case, one just for the controller and tray.
You are very welcome, AerialPerceptions. I'm glad it's what you were looking for! Cheers!
fairyfarmshempgummies
