Field battery charging explained:
This topic was discussed many times here and on other forums, and still remains confusing to many. Since my aerial photography and filming is almost exclusively done in remote landscapes, this issue is of paramount importance. Here are my thoughts, based on real life experience.
Field battery charging is - unfortunately - more complicated than most of us will expect. The reason? Power supply. You need a plenty of stored or fabricated energy available out there. Relatively small, single Phantom or Mavic battery can be charged off a car cigarette lighter or auxiliary output, assuming good shape of vehicle power plant, socket, internal wiring and fusing. DJI's offering suitable chargers for such. However, try to charge more than once or twice without re-conditioning car battery and you may end up looking for a good people with booster cable next morning.
Still, for recreational use this approach may be good enough. For Inspire/Matrice class drones, however, intensive filming in remote locations requires reliable power source. The obvious and simple solution is a generator, 2000W Honda as being the most loved by pros. Add an multichannel charger to feed 4 batteries simultaneously, sufficient number of spare batteries and you're happy. flying without interruptions other than for lunch break.
Than we have solutions for brave ones: huge 12V battery and 1000 or 2000W inverter in the trunk as an equivalent of a noisy and smelly generator. 200Ah led battery weights 60-70kG, but - when fully charged - will provide enough juice to charge several TB48's or TB47's. This approach, however, carry a serious safety issues. Heavy wiring aside, such monstrous load must be securely mounted and isolated, avoiding the risk of catastrophic shorts. Not cheap though.
Here's similar, but cheaper solution, in testing shape. Equally challenging, however, for a few of us only familiar with soldering gun. Huge storage battery is still required, but the charging voltage and current is provided by widely e-Bay available DC-DC Step-Up Converters. In this scenario power is drained from 24 V battery bank with approx. 11.5 A total current, while each Inspire battery drains approx. 5 A charging current. Therefore only 1.5 A is used for voltage conversion, not bad at all. One may want to crank the charging current up a bit, but the benefits are negligible with 5 or so minutes less gain. Here two batteries depleted to 15% were charged in 63 minutes.
Here's a DIY double channel charger for 12 V source, set up for Phantom 3 batteries with moderate charging rate. Note approx. 4.5A charging current for each battery, but the total drain is about 15A! The wiring from battery terminals must be at least of 10AWG to avoid noticeable voltage drop. Converters itself are of CV/CC type (Constant Voltage/Constant Current). allowing for wide output parameters adjustment to charge Inspire batteries as well. In this case, however, the drain is even bigger, reaching 20-25 A current with 12 V source. Naturally 24 V battery will provide much better configuration, but this option may be available for some truckers and boaters only.
Bottom line: drone batteries are hogs and will demand a lot of power. A portable generator is still the best, simple and safe ...
I wonder if the new DJI multi charger for the Inspire 2 (which i see is still coming soon) will offer an in -car mode?
Nope, for above mentioned reasons. To charge multiple batteries of this capacity simultaneously you'll need an enormous power source no car is able to provide without prohibited modifications ...
"prohibited modifications" LOL - we have been charging two 6s5000mh packs simultaneously for our 3D helis and 3D planes for many, many years, in 45 minutes using a Hyperion Duo (or other) connected to our car batteries. We simply start our cars every once in a while to recharge the car battery.
DJI packs are NOT power hungry, but pussy *** packs that can only be charged at 2c Max.
I charge them at 200w each with my own setup.
I'm glad you just discovered something so new, (to you) though and very nice of you to share - :)
OK, I can see you laughing :) ... How about "not recommended modifications"? You must bypass standard cigarette lighter/auxiliary sockets in your car and suck the power directly from battery terminals, using at least 10 AWG wiring. Do you see an average yuppie with "under the X-mas tree found drone" doing this safely :)?
Anyway, I totally agree that DJI packs are charged with very moderate approach when factory 100W charger is employed. I'm recently experimenting with 7.10 A charging current and Inspire batts seems to be quite happy so far with significantly less of charging time.
UlrikeCope
