Final Cut Pro and 4k Footage from X3
Final Cut Pro X - I'm am filming and editing in 4K. My FCPX project settings has the matching 4K output (resolution and fps - 29.97fps). The exported clip is a bit jerkier than the raw footage. Do I have to play with any of program settings to get buttery smooth 4K like the raw footage? I am even notices from degrading when I downsample to 1080p (Which I simply do by creating another project with 1080p settings and copy/pasting the timeline from the 4k clip. I assume this is acceptable.)
Btw, also recording at 1/60 shutter speed and working on a retina MacBook Pro. Below is info from each clip, I am just not video saavy enough to interpret the info or determine if it helps.
Raw clip from the camera:
General
Complete name : DJI_0694.mov
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt 2014.02 (qt )
File size : 146 MiB
Duration : 20 s 487 ms
Overall bit rate mode : Variable
Overall bit rate : 59.9 Mb/s
Encoded date : UTC 2016-08-01 16:50:25
Tagged date : UTC 2016-08-01 16:50:25
Comment : 0.9.138M
©xyz : +47.575498-122.190844+2.500
©xsp : +0.00
©ysp : +0.00
©zsp : +0.20
©fpt : +0.30
©fyw : +90.80
©frl : +0.00
©gpt : -2.20
©gyw : +92.30
©grl : +0.00
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=8
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate mode : Variable
Bit rate : 60.0 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.241
Stream size : 146 MiB (100%)
Title : DJI.AVC
Language : English
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
FCPX Exported Clip
General
Complete name : Temp - 4k - 29.97.mov
Format : MPEG-4
Codec ID : qt 0000.00 (qt )
File size : 77.5 MiB
Duration : 9 s 977 ms
Overall bit rate : 65.2 Mb/s
Movie name : Temp - 4k - 29.97
Description : This video is about Temp - 4k - 29.97
Encoded date : UTC 2016-08-02 17:15:06
Tagged date : UTC 2016-08-02 17:15:57
Writing library : Apple QuickTime
com.apple.quicktime.keywords : Bellevue-Project
com.apple.quicktime.author : Loren Anderson
com.apple.quicktime.title : Temp - 4k - 29.97
Video
Format : AVC
Format settings, ReFrames : 2 frames
Format settings, GOP : M=2, N=15
Codec ID : avc1
Bit rate : 65.0 Mb/s
Maximum bit rate : 768 kb/s
Original frame rate : 25.000 FPS
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.262
Stream size : 77.3 MiB (100%)
Title : Core Media Video
Encoded date : UTC 2016-08-02 17:15:10
Other
Type : Time code
Format : QuickTime TC
Time code of first frame : 00:00:00:00
Time code, striped : Yes
Title : Core Media Time Code
Where are you watching the exported video? 8 GB or 16 Gb of memory on the MB Pro? You need to show us the exported video on YT or Vimeo.
Here is an example where it's down sampled to 1080p. The final clip shows evidence.
I
I saw the studder over the lily pads. Have you tried reimporting that clip and do the edit again? Maybe something went wrong on the import?
I have several times. In fact, it almost looks smoother in the FCPX preview window! It's a bit worse in 4K.
Here is a 4k version. The link should start you right where the jitteryness happens.
2.5 i7 processor
16gb RAM
AMD Radeon R9 M370x 2048mb
Loren,
I only saw jitteryness over the lily pond when you were looking straight down.
This is due to the large amount of data that has to flow for this type of video. Every frame is unique and it can not build from the previous frame.
You probably need better compression to get smoother video from FCPX. I would recommend that you use Compressor for FCPX and see it that solves your problem for you.
Loren,
I agree. Earlier renditions of the video had choppyness throughout. I resolved by making sure no programs were open during export. The lilly pads are the only problem now and I think it's because of the raw footage. That was the one clip that looked bad. My theory is a result of the data coming in and possibly slow SD card writing.
YES, a slow SD card will cause choppy ram footage. I had understood from your original post that the RAW was buttery smooth.
I always use the fastest SD card they make. Do not try to save a couple of buck here.
Currently I am using a Samsung PRO+ micro SD U-3 with a max write speed of 90 MB/s.
It is the write speed more than anything that you care about.
Is there any remedy for distortion on Inspire 1's Zemuse 3? I am not quite sure what happened but on my initial flights, the video seems to be fine... then it shows distorted feed on my iPad as well as on the recorded. Please help!
What exactly do you mean by distorted?
General
Format : MPEG-4
File size : 146 MiB
Comment : 0.9.138M
©xsp : +0.00
©ysp : +0.00
©zsp : +0.20
©fpt : +0.30
©fyw : +90.80
©frl : +0.00
©gpt : -2.20
©gyw : +92.30
©grl : +0.00
Video
Format : AVC
Codec ID : avc1
Color space : YUV
Bit depth : 8 bits
Title : DJI.AVC
Language : English
FCPX Exported Clip
General
Format : MPEG-4
Video
Format : AVC
Codec ID : avc1
Color space : YUV
Bit depth : 8 bits
Other
Type : Time code
Im an editor and would always convert the 4k to 1080p in Quicktime Pro first. I feel I get better results than converting in the timeline.
My ultimate goal was to end with 4k footage and not downsample at all to 1080p.
it's ok... i found the culprit... it's the connector i bought in replace with the iPad. bought a curled connector (i thought it would be a brilliant idea if "no dangly wires" connect from RC to iPad) which is for Android but has an adapter for iPhones/iPad... turns out that the extra connector distorts the stream on realtime view but the good part is once i got it import on MacBook Pro, the video plays perfectly!
I use the six inch cord made by Apple. I have never trusted non Apple cables. They are expensive for a reason, they are much better made.
Is everything played in real time? I sped up a shot that had a similar composure. I had to speed up the frame rate to prevent what you are seeing. Have you tried playing that scene at 59 FPS? I
Final Cut Pro X - I'm am filming and editing in 4K. My FCPX project settings has the matching 4K output (resolution and fps - 29.97fps). The exported clip is a bit jerkier than the raw footage. Do I have to play with any of program settings to get buttery smooth 4K like the raw footage? I am even notices from degrading when I downsample to 1080p (Which I simply do by creating another project with 1080p settings and copy/pasting the timeline from the 4k clip. I assume this is acceptable.)...
marve84
