Firmware
no video signal, and no 1080 25p, it just disappeared after the update. full operating function just no video transmission.
Am I to assume since 1080/25 has 'disappeared' then so to has 1080/50? Are you in NTSC mode which will only display NTSC associated frame rates and therefore you are not 'seeing' PAL compatible rates?
i still have option to select pal, however only NTSC rates available.
What does your log file say? Did all firmware modules update?
Have you checked 'About' status in the app to confirm FW version number for each module?
kailastrendsntrimskailast
