Welcome to InspirePilots.com
Join the leading DJI Inspire community for free!
First Dark Flight X3
Discussion in 'Photos and Videos' started by ringolong, Feb 26, 2016.
  1. ringolong
    Nov 29, 2015
    442
    111
    My first attempt at a night shot. Chattanooga TN.
    jixxer and MacDyver like this.
  2. MacDyver
    Nov 29, 2015
    297
    110
    South Florida
    I think others have not noticed the FAA has removed language prohibiting hobbyists from night flights.
    ringolong likes this.
  3. ringolong
    Nov 29, 2015
    442
    111
  4. MacDyver
    Nov 29, 2015
    297
    110
    South Florida
    Not the FAA website, take note there is no mention anymore of time restrictions for hobbyists
  5. MacDyver
    Nov 29, 2015
    297
    110
    South Florida
    SEC. 336. SPECIAL RULE FOR MODEL AIRCRAFT.
    (a) IN GENERAL.—Notwithstanding any other provision of law relating to the incorporation of unmanned aircraft systems into Federal Aviation Administration plans and policies, including this subtitle, the Administrator of the Federal Aviation Administration may not promulgate any rule or regulation regarding a model aircraft, or an aircraft being developed as a model aircraft, if—
    (1) the aircraft is flown strictly for hobby or recreational use;
    (2) the aircraft is operated in accordance with a community- based set of safety guidelines and within the programming of a nationwide community-based organization;
    (3) the aircraft is limited to not more than 55 pounds unless otherwise certified through a design, construction, inspection, flight test, and operational safety program adminis- tered by a community-based organization;
    (4) the aircraft is operated in a manner that does not interfere with and gives way to any manned aircraft; and (5) when flown within 5 miles of an airport, the operator of the aircraft provides the airport operator and the airport air traffic control tower (when an air traffic facility is located at the airport) with prior notice of the operation (model aircraft operators flying from a permanent location within 5 miles of an airport should establish a mutually-agreed upon operating procedure with the airport operator and the airport air traffic control tower (when an air traffic facility is located at the
    airport)).
    (b) STATUTORY CONSTRUCTION.—Nothing in this section shall be construed to limit the authority of the Administrator to pursue enforcement action against persons operating model aircraft who endanger the safety of the national airspace system.
    (c) MODEL AIRCRAFT DEFINED.—In this section, the term ‘‘model aircraft’’ means an unmanned aircraft that is—
    (1) capable of sustained flight in the atmosphere;
    H. R. 658—68
    (2) flown within visual line of sight of the person operating the aircraft; and
    (3) flown for hobby or recreational purposes.
  6. jixxer
    Sep 27, 2015
    55
    19
    GREAT SHOT KEEP UP THE GOOD WORK
    Droneworx and ringolong like this.
