fix Inspire 2 rattling props forever. free of charge, in 30 minutes.
mit
all you need is unscrew propmount, cut ring from thin film like this TABpro protective film, put this ring (3) between two plastic parts (1) and (2) and reassemble prop mount. thats it. it will hold your propeller firmly as it should do. no foam (does not remove vibration) or any glue (temporary) on the props needed.
quarecresources
