Fly-to and waypoint app
Hey folks,
Have searched my answer and unable to locate. Currently using inspire 1 with airnest and maps made easy map pilot and quite happy in regards to their fit with the missions I require.
Problem is;
1. In map pilot is there a way to "fly to" an area to create a mission? Simply, if I'm travelling across state to an area for a flight and provided Lat/long or utm of the area, is there any way to enter them into map pilot to make the map "go to" that spot and then create the mission?
2. Is there an app in existence I can use to make and save a mission with provided waypoint coordinates? If I'm provided three sets of waypoint coordinates in a large field, I'd like to make and save the flight using the coordinates prior to going to the location?
Hope this makes sense, it's late!!
Thanks in advance
I am using Autopilot. (Apple IOS, iPad required)
You create a waypoint mission in Mapping format.
Enter the map and enter the Lat/Long coordinates.
Autopilot then creates a mapping path which you can alter as you wish.
This can be done at home and the mission(s) can be saved.
On location, just load (it's on the iPad) and execute the mission.
I hope this helps,
regards,
K.
cruzamikayla
