- Joined
- Aug 7, 2013
- Messages
- 10,825
- Reaction score
- 5,701
Guys,
There have been a lot of reported issues with the USB module going out on the Inspire remote and I cant help but think that some of the problems may have been caused by constant wear and tear on the USB socket itself.
The ones used on the Inspire remote are not the greatest quality and continual plugging and unplugging of a USB lead can not help matters.
I wanted to just share a little tip I have utilised pretty much from day one and I have four remotes and never had an issue with any of them.
I have not seen anyone else using these little USB adapters which totally takes the strain away from the main socket and should the adapter fail it is a 30 second job and a £1.50/$1.00 swap to get up and running again.
USB Adapter
Connected and strain taken off with cable ties
Connected in TX Tray
Ditto
Ready to go flying!!!
(Bottom of thumbnail cut off - but click on the image and you will get the idea
Make sure you order a left hand or right hand adapter depending on which way you want the cable to exit.
Hope this helps some of you guys.
USB Adapter
Ditto
