Gimbal Pitch/Yaw Not working
When I select reset yaw for c1 or c2 it works just fine. But when I select reset pitch/yaw nothing happens when I hit the button. Anyone else have this problem?
Mine started doing it after I did the latest firmware update. I'm also noticing that the camera pans a few degrees when I move the directional (right) stick. The left stick was causing the camera to tilt a few degrees as well, but after restarting both the Tx and the aircraft only the slight pan/right stick issue remains.
Maybe I'll try reinstalling the update for the remote.
Mine does this. I could yaw the camera with the Gimble control on the controller, it's all out of sync!
princelak
