GPS ENCOUTERS DISCONNECT
Is this the external RC GPS Module ?
Tbh if it's the craft one as the Inspire 2 is less than 12 months old any issues like this should be warranty unless you fixing a crash repair and then you could have all sorts of other issues.
Are you saying you have changed the GPS abut it's the same ?
If that's the case other than making sure the fw is all correct then I would send it in for repair.
Gotta ask it but you're 100% positive you reconnected the GPS Module back to the Central Board when you installed the Upper Shell back on the aircraft? Secure connection and no damage to the GPS port on the board?
BobbyeriGop
