Having trouble callibrating the joysticks on controller.
Having trouble callibrating the controller joysticks. When asked to move joysticks up and down to 100% repeatedly in every direction nothing seems to happen. Whats the trick to this seemingly simple callibration to stop controller beeping continuously. Thanks
is that part of the same callibration routine.... I have moved bothe left n right joysticks up down left right repeadedly and nothing happens.. so finish button does not highlight.. am I meant to roll gimbal each way aswell?
I assume you have the aircraft switched off yes?
As per the instructions, your aircraft must be off and you must complete 100% stick travel on all axis INCLUDING the gimbal wheel to end stop at both ends.
apexwebcube
