Hdmi wifpreless sender - advice please?
Should work if the tiny range (30ft) is enough for you.
Whether it disturbs the link with the Inspire will need experimentation.
I fly an inspire solo and want to display the video feed to a 12v TV on a tripod for clients to watch.
I am using a cable at the moment but having tripped twice now I need a wireless solution. Getting a second controller for this seems a little overkill!
It transmits on 4.9~ 5.9GHz
I spotted this:
ARIES Prime Wireless HDMI Transmitter & Receiver System | Nyrius
Any advice?
Looks interesting - better than a 30ft cable if it works.
IMHO will probably be okay as your operating solo. I would be interested with dual controllers but it could potentially interfere with the 5.8GHz controller to controller signal. However I see it uses DFS which may overcome this problem.
We really need an expert on this subject to pass comment - hopefully our Editor will have the answer..........
The range is only from the controller tothe telly so 10 metres is fine. If it works!
Sent from my E5823 using Tapatalk
Honestly...I'd just purchase another slave Inspire 1 controller...that HDMI is trouble free and can hang adjacent to the monitor. The price for used has dropped considerably.
Except that the range/breakup problem from slave controllers is still a thing.
We've been using a Connex to retransmit the master's signal the same way he wants and that works, so the one he linked should as well (same tech).
Reactions: mikeL
Problem solved
Having done a little digging people are already using these actually on their drones with the Pro version. The lag is minimal and fine for AP work but a bit slow for racing! It look like it will fit my needs fine so time to order ;-)
160 foot range but apparently with a modified antenna up to 1000 feet!
https://www.amazon.com/Nyrius-Wireless-Transmitter-Projector-NPCS600/dp/B0092T3E3A
We use the paralynx arrow plus, nice bit of kit. Annoyingly it does not work with a atoms shogun which I already own.
Reactions: mikeL
Bcloughpmd
