HEADPLAY ISSUE!
United States,Houston, Tx
I've had my HEADPLAY unit working with my Inspire since they released them last year with zero issues. However after I did the recent firmware update on the I-1 (1st edition drone), and attached the HP unit the HP unit worked as always, but I received no output on my pilot app side. Unplug the HP unit and the pilot app side works fine with either my iPad or iPhone. I checked the connections & plugs and everything was ok, but same results??
Anyone else out there with this same issue? If not any ideas on a remedy?
Thanks for your help!
M
No that doesn't stick out to me.. But diffently sounds like a Great suggestion & will try that. Just so I'm clear, is that a setting I would do before starting up, like a camera setting? Or.....?
Thank you so much for your very fast reply!!!
M
It should save for future once set as long as the app is not installed, and then re-installed.
M
BTW: everything started working perfect the next time I used them, and no issues since.
Moose
GroverBaez
