R Ruff Ryda Joined Oct 13, 2015 Messages 6 Reaction score 6 Age 50 Oct 26, 2015 #1 I wondering if there is a fix for the gimbal not pointing straight forward. It appears to be off by a degree or two. Thanks in advance.
L lovetofly Joined Apr 24, 2015 Messages 81 Reaction score 21 Age 64 Oct 27, 2015 #2 Hi, Had the same issue and performed a Gimbal calibration, problem solved.
R Ruff Ryda Joined Oct 13, 2015 Messages 6 Reaction score 6 Age 50 Oct 27, 2015 #3 lovetofly said: Hi, Had the same issue and performed a Gimbal calibration, problem solved. Click to expand... I've done a IMU cal and a gimbal cal, but it still is off.
crashburn Joined Jan 3, 2015 Messages 346 Reaction score 178 Age 73 Oct 27, 2015 #4 With new rc firmware upgrade can you longpress c2 and then use right wheel to calbrate gimbal, especially if just couple of degrees?
R Ruff Ryda Joined Oct 13, 2015 Messages 6 Reaction score 6 Age 50 Oct 27, 2015 #5 crashburn said: With new rc firmware upgrade can you longpress c2 and then use right wheel to calbrate gimbal, especially if just couple of degrees? Click to expand... I think that's for roll isn't it? Mine is off on yaw or the "Z" axis.
