Welcome to InspirePilots.com
Join the leading DJI Inspire community for free!
Hot weather flying..Arizona
Discussion in 'Inspire 1 Discussion' started by Jimmykjimmy, May 12, 2016.
  1. Jimmykjimmy
    Oct 20, 2015
    179
    30
    Well summer is almost upon us. I normally fly before sundown. The temps here can be pretty high at that time..85-95F. I know the batteries will not charge above 104, but what happens when you try to fly in the aforementioned temps?
    Any experience, thanks.
  2. DesertWindAero
    May 1, 2016
    158
    39
    Northern New Mexico
    When flying in hot weather like that, I keep unused batteries (I have 12) in my running vehicle with the A/C on full blast, so I am able to start off each flight with a fully-charged, cool battery. Haven't experienced any problems.
  3. go fast
    Jul 16, 2015
    277
    122
    Miami Fl.
    If you use an iPad it might not be too happy...
  4. Jlarcher
    May 29, 2016
    24
    Scottsdale AZ
    iPad Operating temperature: 32° to 95° F (0° to 35° C) I use ice packs to reduce the temp between flights
  5. Charles.mabry
    Mar 22, 2016
    147
    14
    Prescott, Az
    95? What part of Az?
  6. Jimmykjimmy
    Oct 20, 2015
    179
    30
    Here's a recent healthy drone battery analysis on a recent flight. The battery was kept at ambient temp ~80 deg. The temp outside was between 83-87. This was the third flight with the same battery, not long because the battery was close to 30%. Everything went well, but if I were to use another battery it would have been in a cooler to make sure it didn't get too hot. This battery is relatively new. So this would appear to be slightly over the recommended 48C.
