How to fix fail safe.
I was putting my I2 in its case today, and from about 7 feet up two wooden cutting boards fell, both landing on the right rear motor. The only damage was that the antenna cover partially popped out. How do I fix this?
Wedge a pencil or small screwdriver between the cover and the bird like a fulcrum (near the center of the cover), then bend the cover toward the bird so the tab fits back in. If you need more space, use a larger fulcrum. Remove pencil/screwdriver.
Turns out there was 4 screws holding it in. You just have to undo the 4 screws, pop it back in, and you’re good to go.
AdolphJuq
