Getting more accurate altitude data from EXIF
hello everyone
I posted this on the Photoscan forum so I thought I'd post it here as well. Its for getting more accurate pre-processed elevation data out of the EXIF meta-data that might be useful for some on here. Improvements welcome of course. This is currently what works best for me but still a work in progress.
OBJECTIVE
For non-survey grade projects without using pre-sampled Ground Control Points, to get as accurate as possible elevation data prior to processing in Photoscan Pro. In other words to get the most accurate map/model/orthomossaic/DEM etc as possible without using RTK GPS.
PROBLEM
The usual metadata tag that is used by these applications is the ‘GPSaltitude’ tag. Currently DJI populate this from the aircraft's GPS unit. The altitude recorded here is grossly inaccurate. We need to fix this as far as we can.
BASIC WORKFLOW
  • Establish and record the barometric altitude above mean sea level of your take-off point using an app.
  • Back in the office we need to process the meta-data from all the photos taken poking a more accurate figure into the GPSaltitude tag.
Thankfully DJI do record another tag called RelativeAltitude which populates the tag based on the height above your take-off point using the aircrafts barometer.
We want to add this RelativeAltitude value to the calibrated barometer reading we took from our phone/device at take-off to come up with an altitude above sea level figure for each photograph.
Then we want to write this combined value into the GPSaltitude tag that Photoscan Pro can use.
thanks
Reactions: eldorado
hello everyone
OBJECTIVE
PROBLEM
BASIC WORKFLOW
thanks
I posted a step by step on this on the Photoscan forum and here year ago...theres about. There are 2 Python scripts that do this the easy way now. Sorry I'm only on my phone right now so no links, but they are there in the Photoscan forum.
In fact the OP in rhis thread is a cut and paste from my original post on both forums! Not great posting it as if it's your own work!
Search in this forum for "Sorting out DJI's bad GPS altitude". Sorry no direct link...still only on TapaTalk.
Reactions: eldorado
Thread title changed to something a little more descriptive than "i have problem"!
codymorgan
